Thread: Drawing projections - QUESTION
    Jul 2018
    Confused Drawing projections - QUESTION
    Hello everybody, new in the forum.
    Hope you can help me with this basic doubt.
    The attached pdf contains 3 options dimensioning the same part (formed channel)
    Can you help me to idetify wich ones are correct or incorrect?
    Thanks, appreciate your help!
    Attached Files Attached Files
    2,365
    First or third angle projection?
    190
    my 2 cents:
    Either 2 or 3 are correct third angle views. Two seems more comfortable.
    The 2.50 can be eliminated as it is double dimensioning.
    The 5.63 between the two views as on option 3 makes it easier to relate the dimension to front and side views.
    There is no call out for the corner breaks.
    Jul 2018
    Thanks for your replies.
    All are 3rd angle projection.
    I understand that option 1 is not correct.
    Greetings!
