Thread: piping dead weight calculation
    ashish_shrivastava
    piping dead weight calculation pdf for reference
    Attached Files Attached Files
    New Member
    Apr 2023
    To calculate the dead weight of a piping system, you can follow these steps:
    1. Determine the weight of each individual piping component, such as pipe, fittings, valves, and supports. This information can typically be found in manufacturer's catalogs or engineering data sheets.
    2. Multiply the weight of each component by the number of units used in the piping system.
    3. Sum up the weights of all the components to obtain the total weight of the piping system.
    4. Add any additional dead weight, such as insulation or corrosion protection, to the total weight.
