Thread: Title block tolerance applied to hole diameter with geometric positional tolerance
    Jul 2019
    When the position of a hole is established using a geometric tolerance, is the title block tolerance automatically applied to the diameter, or is it required to repeat the hole diameter tolerance even if the tolerance is the same as listed in the title block? Is it considered redundant to repeat the title block tolerance for diameter on each hole using a geometric positional tolerance?
    If someone could point me to a particular section in Y14.5-2009 where the specific requirements and hierarchy of title block tolerances vs geometric tolerances is described, that would be appreciated.
    2,313
    See ASME Y14.5-2009, sub paragraphs 1.4 a, c and d.
    Jul 2019
    If the sheet tolerance applies to the diameter of the hole, I do not repeat the tolerance.
    2,313
    Quote Originally Posted by jasonamurawski View Post
    Yes, in general there should not be any redundancy in tolerance or dimension specifications. Can cause confusion and even conflicting requirements.
