Thread: Mounting a planar mirror with epoxy
    Jul 2019
    I am looking into ways to mount a cylindrical-planar mirror to be used in a low-pressure, thermally varying environment.
    Our current method involves directly pushing onto the mirror, which can flex or damage it. My boss has asked that I look into using epoxy to adhere it to the mounting face.
    After around an hour of looking into it, I haven't found much in the way of technical papers that give advice to the process/geometry of the mounting face. What I have heard is that I may want to look into adding a groove or two to help with thermal expansions of the epoxy, but I haven't found much to corroborate that.
    Is there anything I should be aware for using epoxy? Is it really so simple that I can just have two planar faces epoxied together?
    Thanks!
    2,314
    Quote Originally Posted by harrisonczaj View Post
    Well, yes it is. For example, if you own a car the rear view mirror mounting base is "epoxied" to the glass. Grooves can help with selected materials though I would consider circumference location/securing in addition to bonding.
    Also, I would reach out to a adhesives applications engineer at one of the big chemical companies, like 3M ad others.
    May 2015
    183
    Consider a urethane adhesive for windshields.
    https://www.3m.com/3M/en_US/company-...3242009&rt=rud
