Thread: Lever arm design
    Lever arm design
    Hello everyone,,
    I am an engineering student working on a project to design a trash compactor, I have decided to use a lever arm. The compactor will be operated by a person pushing down the lever arm at position C in diagram below, this will push a plunger attached at point B, I need to get 1200kg/m3 in the bale, so with the area of the compression plate I have calculated that the force required will be 171N. I need to design the length of the lever arm and then the minimum size for a timber lever arm and a steel box section for an alternative. I have looked through a number of online calculators but none match my setup. I would really appreciate it if someone could help me with how to go about designing this or what book or web resource would help me.
    Thanks in Advance,..
    2,611
    Engineers Edge Static's 2D modeler and Structural Calculator will allow you to define any mechanism and applied loads you want.
    See: https://www.engineersedge.com/calcul...d-modeling.htm
    Perfect! That's really great software for modeling 2d Statics.
