Originally Posted by
JAlberts
If you are using two connecting shafts, it would seem that their connection point must be inside some type of enclosure and the 8 mm shaft and handle will only be connected periodically "for maintenance purposes"; so, it seems it would be preferable to have some type of simple slip on connection.for the connection to be a simple slip-on type of connection.
Can the 12 mm shaft have some type of larger diameter collar mounted on its connection end? If so the connection could be a slot and tang type of connection (slot in 12 mm shaft end and mating tang on the 8 mm shaft end with a collar extension mounted on the end of the 12 mm shaft to guide the 8 mm shaft.
