Thread: GD&T floating Fastener Formula question
    Feb 2017
    6
    Good Morning Folks,
    Hopefully my question is an easy one concerning the “floating Fastener Formula”. I understand the FF formula as it applies to the typical joining of two surfaces such as a simple joint assembly where a clamping force is required from a floating fastener (T = H - F). However, my question is concerning scenarios where multiple layers, or great than two, come into play such as a telescopic tubing assembly. The fastener goes through at least four layers of material. In cases such as that, does that need to be factored into the FF formula? Would the resultant tolerance need to be divided by the amount of layers?
    Thank you!
    2,594
    Quote Originally Posted by james_kashuba View Post
    Good Morning Folks,
    No, each layer "floats" because the features are clearance holes / features. Just like with two floating parts assembled by a through fastener the four features may require full assembly with all fasteners un-tighened to ensure assembly.
    Feb 2017
    6
    Thank you Kelly! I needed that confirmation
