Results 1 to 6 of 6
Thread: No. of Holes
    Feb 2017
    No. of Holes
    I am design valve disc how to calculate the no. of bolts required to for valve seal Clamp in it's position.
    420
    Does this container pressurized and if so to what pressure; and what type of cover seal are you using?
    Feb 2017
    Yes, it's pressurized about 16 bar and i am using rubber seal.
    420
    Is it a flat gasket or O-ring type seal? Have you done the design pressure load and stress calculations for the cover plate?
    May 2015
    168
    Multiply the pressure times the area inside the gasket to get the force trying to push the cover off the valve. The total clamp load of the bolts should be several times this value. How many times depends upon engineering judgement.
    So make the clamp load ten times the lifting force and see how it looks.
    Jan 2020
    There is a page on the website related to this exact subject:
    https://www.engineersedge.com/genera...ompression.htm
    Another consideration you can make for bolt circles on sealing flanges is spacing of the bolt frustum.
    Long story short: each bolt makes a cone shaped stress region below its head. If you make those cones overlap then you end up with a high performance flange that resists leaking. May be overkill for your application since it's just 16 bar.
