Results 1 to 6 of 6
Thread: Calculating flow rate from air to water
    Jun 2020
    Im currently looking at a symstem where air is pumped down a pipe and up through a bigger pipe which lifts water from above. Just wondering if there is anyway of calculating what the flow rate would be through the water if i know what the air flow rate it.
    Any help would be appreciated.
    Cheers.
    853
    I've read your question four times and have no idea what you're asking. A diagram would help.
    The air is "lifting" the water? From above? Huh?
    Jun 2020
    Oops I meant lifting water from below.
    2,355
    Quote Originally Posted by miked_27 View Post
    Cheers.
    Flow rate will be derived from differential pressure, size of pipes, etc..
    And, yes there is a way to calculate flow in defined fluid systems - - but you have not provided any usable information on what that system is.
    Jun 2020
    Sorry it's a dredging system. Air is pumped down the annulus pipe and flows into the main bore at the bottom and this main bore is filled with water.
    853
    Upon encountering the water the air forms bubbles and rises to the top surface of the water. How is the air "pushing" the water anywhere? Unless there's enough airflow to overwhelm the water with unmanageable bubble sizes.
    "Just wondering if there is anyway of calculating what the flow rate would be through the water if i know what the air flow rate it." That makes no sense. First you ask us how to calculate the flow rate through the water, then you tell us you know what the air flow rate is. Sorry. Just confused.
