Thread: Gear that can interpolate between two input gears
    Jun 2020
    I'm looking for a type of gear system that can do the following:
    There are three input gears: A, B and control C
    There is an output gear O.
    If control C is rotated to the left, O has the same rotation as A
    If control C is rotated to the right, O has the same rotation as B
    If control C is something in-between, the output O is a linear interpolation between input A and input B, so it smoothly goes from the one to the other as C goes to the right.
    None of the gears need to be able to make full rotations, just from left to right. So if A is pointed left and B is pointed right, C going from left to right makes the output from left to right. But if A is pointed right and B is pointed left, C going from left to right makes the output go from right to left. And if A and B are equal, rotating C does nothing, the output is equal to both inputs then.
    I thought something like a differential gear or planetary gears might be able to do it, but I can't find anything that works. Ideally it'd be as simple as possible.
    Any ideas? Thanks!
    2,344
    Ratchet actuated gears... Ratchets work in the direction of intended operation.
    See:
    https://www.engineersedge.com/calcul...sign_15333.htm
    849
    Study the workings of a differential gear set used on automobiles. Its a pretty amazing innovation. A variation of that arrangement might work for you.
    188
    Following up on Kelly's idea, look at overrun clutches and one way clutches.
