Thread: applying significant digits to a geo tolerance in a feature control frame
    Feb 2020
    If I have a feature control frame with regards to flatness, and the geometric tolerance is to .001", do you still apply significant digits to that number?
    Ie. my mech insp. measures the part, and comes up with a flatness of .0013", is that within tolerance, because it is to 3 significant digits and .0013 rounds down to .001?
    -Or- because it is in the box it is a drop dead number, maximum, so .0010000001" technically is out of tolerance?
    I have read that the geometric tolerance is total, not a +/-, but this isn't really talking about that.
    This has come up before at work, and we are still not exactly sure, so if you could point to where it mentions that in the standard, I would appreciate it. I am ok if it is a common knowledge thing too.
    Thanks,
    JimL
    2,613
    ASME, ISO or whatever...
    Tolerances are not rounded. Flatness .001 = .0010000000000000000000000000000000000..... infinity
    Your metrology equipment should be 10X more repeatable for imperial units and 5X for SI.
    Feb 2020
    Ok, so are you saying all tolerances are not rounded, or just the tolerancing in a control frame? Also, could you point this out in the standard?
    I am going to have to argue my case.
    Thanks,
    JimL
    2,613
    Quote Originally Posted by jamesl View Post
    Thanks,
    JimL
    ASME Y14.5-2009, Paragraph 2.4 "Interpretation of Limits"
    This is very-very basic knowledge, your organization needs training ASAP.
    See:
    https://www.engineersedge.com/GDT_Training.htm
    2,613
    Also, ASME Y14.5-2018, Paragraph 5.4.
    and
    ASME Y14.5M-1994, paragraph 2.4
    and
    ANSI Y14.5M-1982, paragraph 2.4
    and
    ANSI Y14.5-1973, paragraph 2.4
    and
    ANSI Y14.5M-1966, Section 1
    Identical text as ASME Y14.5-2009
    Feb 2020
    Kelly,
    Thank you so much for your time, I appreciate it.
    JimL
