Thread: set SI-units
    Jan 2021
    set SI-units
    ipt>
    I just took a premium year subscription.
    But I see US-units (inch, LBS etc.) is default.
    In the Netherlands (EU) we use the SI-system (m, s, kg).
    Where on the site can I set SI-system as defualt?
    Most calculators are unit less unless otherwise indicated.
    For example:
    https://www.engineersedge.com/beam_b...flection_3.htm
    The units are suggested for the Modulus of elasticity: lbs/in^2 or N/m^2.
    If using SI units keep N/mm^2 and then mm for the other inputs of the calculator.
    Keep units consistent with either SI or imperial.
