Results 1 to 18 of 18
Thread: Spur gear?
    Spur gear?
    Hi I’m trying to find a gear 26t 49mm O/D
    I’ve attached a picture
    Where have you looked?
    I’ve tried the 3 different companies, plus I’ve spent hours looking on the internet with no luck!! Any help would be appreciated.
    Have you identified whether it's metric or imperial (inch) standard?
    2,613
    I doubt it's an off-the-shelf gear.
    Probably need to find somebody that can reproduce it from what you have
    It’s used to to drive a limit switch on an electric motor, pretty sure they would be massed produced, if you knew the part number probably would find it straight away.
    This is the switch
    No I haven’t, how would I go about this?
    I agree with Kelly. I don't think its an off-the-shelf gear. From the photo it looks like it is custom made for that particular product. You could try the switch manufacturer, or whoever owns them now.
    The switch and motor manufacturers are the same people. It’s a basic setup with a gear from the motor driving an intermediate gear which drives the switch all the same o/d. I’ve taken a picture of the maker mark.
    Quote Originally Posted by willrnewman View Post
    This is the switch
    From that picture it looks to be die cast and probably in aluminum or zinc.
    If a replacement cannot be found then you would take the gear to a machine shop and ask for a reverse engineered gear built from the existing example.
  14. #14
    Spokane, WA
    130
    I've had to make something like this a few times recently.
    It looks like the gear has 26 teeth; a fairly normal configuration.
    The only other thing a machinist would need to know is the diameter.
    Then I'd go to Boston Gear website, and find the one that is closest to the bore diameter / hub configuration, and modify that to fit.
    A fairly simple job really. (uumm... if you have the proper tools )
  15. #15
    Spokane, WA
    130
    Went back and read the original post.
    (should've done that first).
    26t and about 1 15/16" OD.
    That doesn't seem difficult to find.
    Just have to modify (probably) the hub/bore to fit your application.
  16. #16
    Good luck in finding. It happens so often with me, as soon as a certain thing is needed, then it is nowhere to be found.Recently, I needed a linear actuator to automatically close the door and barely found a website where I could order exactly the one I needed. But I spent 3 days looking
  17. #17
    Apr 2021
    Germany
    11
    Hi
    I'm new in this forum but it seems to me you cannot find an off-the-shelf part why you don't use planetary gear for reducing the numbers of turn?
    Enable GingerCannot connect to Ginger Check your internet connection
    or reload the browserDisable in this text fieldRephraseRephrase current sentenceLog in to edit with Ginger×
  18. #18
    Apr 2021
    Are you set on 26t , 49 O/D ? may have options for you
