Thread: Cantilever Jib Crane mounted to Stud Wall
    ipt>
    I want to mount a Vestil Manufacturing JIB-LC-10 wall mounted jib crane to a wood stud wall covered with 5/8" type X gyp board at the back of my garage. Will the wall support the thrust and pull values of a jib 8'-0" long with a maximum 1000 lbs load and the thrust and pull values listed as 3459 lbs each way? The wall mounted crane will be used to raise a 486 pound lawn tractor up onto a 5'-0 high wood storage platform.
    Newark, NJ
    296
    Can you provide a free body loading diagram?
    Apr 2021
    Germany
    11
    Hi
    It depends of how far do you lift the load from the wall. It's so important. and let me know if you can use a steel bar or wire cable for support behind the wall.
    May 2021
    Every time I walk into a Walmart and see the bicycles stored by hanging them from one flat roof truss for 50 feet, I think of things like this.
    A wood structure garage is not just one of many components working independently. It's a combination of all it's components working together. Loading a wall in a wood structure that's not designed for it is a bad idea. And modifying it without an engineering calc and a building permit will leave you liable for any disasters a failure may create.
    Located in just the right spot, a few missing nails during construction, non-structural lap locations in the plate and sill, anchor bolt locations, you could possibly pull the building down with 1000# point load? And your insurance won't cover you.
    Wall mount swing away are fine if you design for them in advance. Otherwise use a post in retrofit applications. Cheaper and easier to cut a concrete floor to add the anchor. And you can still have a swing away with about the same clearance away from the wall. And the concrete anchor calc is an easy DIY. Best of all .... no permit and no liability.
