Thread: Feature of size
    Feb 2021
    8
    Feature of size
    Folks I'm diving into the GD&T magical world and now I'm learning about feature of size although something is getting me confused. When I talk about feature of size the first thing comes in my mind is that a feature of size is a feature... Taking this simple part below, it's easy to me recognize the hole as a feature and a feature of size because it has a cilindrical surface (so it's a feature) and a directly dimension associated (so it's a feture of size). Up to now everything is fine. But when it comes to the thickness of the plate my mind blows up!! I can recognize the two parallel oposed surface and the directly dimension associated with this althouh I can not see the feature itself... Reading a bunch of articles and watching another bunch of videos when people identify something as a feature of size they point to a dimension not a feature...
    So my question is: "Is feature of size a dimension or a physical portion of a piece?"
    Taking the hole as example: What R E A L L Y is the feature of size: the hole itself (the physical thing which is made by drilling process) or the Ø8 mm dimension?
    2,544
    In general a FOS is a feature that has surface elements that are directly opposite of one another and is specified with dimensions and is toleranced. Such as a cylindrical surface (hole or shaft), spherical surface, a circular element, or a set of two parallel line elements or opposed parallel surfaces (thickness) associated with a single directly toleranced dimension.
    A feature is any surface element, plane, half circular surface like a radius, etc...
    Note that there are actually two types of Feature of Size (FOS) called "Regular Feature of Size" and "Irregular Feature of Size".
    Feb 2021
    8
    Alright! That’s what reading from multiples sources although when comes time to point where are the feature of size they point to a dimension not to a feature… Specifically talking about the FOS associated with thickness of the plate which is the FOS? The bottom surface, the top surface, both are considered feature of size, or both forms one feature of size?
    2,544
    Quote Originally Posted by ivanginato View Post
    For a plate, the top surface would be a feature and the bottom surface would be a feature as well. These two separately are plane features. The thickness will and should have a dimension and tolerance specified somewhere thus referencing the thickness and that associated dimension and tolerance it is a FOS.
    Feb 2021
    8
    Ohhh yeah!! Now I feel like bender’s meme from futurama: “Now I see it, now I got it, now I all the piece are fall into place” 😂😂
    Thank you, Kelly!
    2,544
    Thank you, Kelly!
    Just a side note, the top and bottom surfaces as referenced above are known as "Features without size".
