Thread: Calculating shear in a pin with known torque value
    Engineer
    May 2019
    Oklahoma
    11
    ipt>
    I'm working on a design, where a pin is attached to a drum and is used to engage and disengage the drum that is attached to a keyed shaft. I know the torque value on the drum clutch but how do get lb-force unit to calculate allowable shear stress in the pin? I've attached a picture showing how the pin engages into the drum clutch. The drum clutch is keyed to a shaft that is chain driven by a hydraulic motor/gearbox.
    Thanks,
    Alex
    2,570
    See image on bottom for clarity.
    Torque = Force x distance
    or
    T = F x L
    and
    F x L = Fp x Lp
    Thus (algebra)
    ( F x L ) / LP = Fp
    Fp = force on pin
    LP= Length from rotation
    Determine whether you have single or double shear, then use one of the following links to calculate the shear in the pin.
    Single Shear Pin/Bolt Calculator
    Double Shear Pin/bolt calculator
    Engineer
    May 2019
    Oklahoma
    11
    Thanks Kelly!
    So, with the pin being held by the bushing and the actual torque being applied to the portion of the pin below the bushing (see pic attached) I'm assuming "Lp" would be from the bushing engagement to the center of the material where the pin is engaged in the clutch (clutch being the torque on the pin)? The actual pin length is much longer than where its being held and where the force is applied (2nd pic attached.)pin engage.jpgpin_bushing_clutch.jpg
