Thread: Help with axial loading
    Jun 2024
    I need help determining if the Axial loading of the specified Versa Lam Columns is sufficient for the structure.
    The basic build is a two-story structure with 8' ceiling heights and exterior walls made of 2" x 6" common construction.
    The first floor has walls on three sides with an interior open space supported by columns.
    The second floor also has 2" x 6" exterior walls and 2" x 4" interior walls.
    Typical UBC live load 40 psf and dead load 10 psf, No snow or roof loading.
    I will attach a drawing of the specifics and details.
    My main concern is whether the BC Versa Lam LVL 1.8E 2650 5-1/4" x 7-1/4" Columns can support the second floor.
    There are two different spacings, 16'-0" O.C. and 12'-0" O.C.
    I prefer the 16' O.C. if it is structurally sound.
    Boise Cascade gives the following ratings for the Versa Lam LVL 1.8E 2650 as follows:
    Allowable axial load (lbs) 8'-0" length
    100% = 35,760
    115% = 38,090
    125% = 39,480
    If anyone could do the math, I'd greatly appreciate it.
    And like the Professor always said - Show your work.
    Thanks
    Attached Files Attached Files
    Sounds like you're asking for free engineering help.
    2,624
    Quote Originally Posted by wkenddad View Post
    Homework not allowed.. Reread the forum rules..
    Thread closed to further comments. Please use resources approved by your Professor.
