Thread: Water cooling systems?
    Banned
    Jan 2012
    14
    ipt>
    Hi all,
    I am trying to build a water cooling system to cool some electronics however I need to be able to maintain the temperature of the electronics at around 12 degrees C for several hours. Do you have any recommendations for radiators or other devices that can achieve this kind of temperature in a room temperature of about 20 degrees C?
    Thanks a lot.
    Harry
    It is highly unlikely that you can achieve that with a passive radiator/heat exchanger. How would you get the air exchanger cool below ambient? You will need a refrigeration unit.
    Since you didn't indicate a scale, maybe start here...
    http://www.chilleroutlet.com/chilleroutlet.htm
