Results 1 to 6 of 6
Thread: Spring Alternate Sought
    theredbaron
    'm working on a small design idea and need a spring to bend/flex on a punching impact.
    a metal spring, if caught by this blow would obviously cause an injury and I am therefore seeking an alternative such as rubber.
    So far I have been unsuccessful finding anything that could be used.
    Any Ideas?
    Hi and welcome to the forum,
    You might want to do a search... die springs or punch springs. I'm not very involved with punch work but I recall seeing gas springs out there for this sort of thing. Also might consider Bellville spring washers?
    Good Luck,
    Bob
    Most spring manufacturers offer urethane springs for this very type of appplication. Contact one or two of the larger houses. They can help you out.
    Ummm, Bob, slow down. I think he is talking about fist/hand/slap punches on his device.
    Oh...
    Yep after re-reading the original post I see that now. Doh!!
    Apr 2012
    8
    Confused
    Not sure what the application is, but that is also how I read it. Why not use some type of foam pad over a backet attached to springs? I assume by bend/flex you mean to compress?
