Attached below is a basic Paint sketch of the pipeline I am designing here. What I need to know is, how do I calculate the TDH for this? I can't get pumps sized until I know what pressures I'll be working with. Each little black square is a tank battery, which is just storage tanks that will hold saltwater, and a pump to push it into the pipeline. All of these tank batteries feed into one disposal site, the red circle, where the brine will be pumped back into storage tanks. Starting with the upper branch, do I begin to calculate head considering the difference in elevation, friction-loss, etc from point E to the red dot, and then do the same from D to E, and then from C to D, etc. Or do I just use the overall length and endpoint elevations only? This pipeline will be in northwest North Dakota, a fairly hilly area, so the elevation between any two nodes could change by a hundred feet or more.
