Engineering Design Data: Menu - excel calculators > Design Engineering
Design and engineering related excel spreadsheet calculators
Prev Page | Next Page
Pages: 1 2 [3] 4 5
Skirt Support Vertical Column Pressure Vessel Equations and Calculator
Pressure Vessel Skirt Support for Vertical Column Design Spreadsheet Calculator. Design calculations for pressure vessel per. ASME Section VIII, Division 1.
Partition Plate Design Spreadsheet Calculator
Pressure Vessel Partition Plate Design Spreadsheet Calculator, Design calculations for pressure vessel Nominal Pass Partition Plate Thickness per. Table RCB-9.131, TEMA (RCB-9.13)
Pressure Vessel Nozzle Design Spreadsheet Calculator
Pressure Vessel Nozzle Design Spreadsheet Calculator. Design calculations for pressure vessel nozzle per. UG-37, Appendix 1-10, 1-7 and div 2.
Cylindrical Shell Internal and External Pressure Vessel Spreadsheet Calculator
Cylindrical Shell Internal and External Pressure Vessel Spreadsheet Calculator. Design calculations for both internal and external pressure applied on shells.
Pressure vessel Flange Check Design Spreadsheet Calculator
Pressure vessel Flange Check Design Spreadsheet Calculator per. ASME Section VIII Div. 1 & TEMA 9th Edition
Storage Tank Design Spreadsheet Calculator
Storage Tank Design Spreadsheet Calculator per. API 650
Floating Head Exchanger Design Spreadsheet Calculator Pressure Vessel
Floating Head Exchanger Design Spreadsheet Calculator Pressure Vessel AES Type
Tube Sheet Design Spreadsheet Calculator
Tube Sheet Design Spreadsheet Calculator per. API 650
Weld Fatigue Life Analysis of Welded Structures Spreadsheet Calculator
Baseplate Large Moment to AISC LRFD Spreadsheet Calculator
Design Baseplate with Large Moment to AISC LRFD Spreadsheet Calculator
Pages: 1 2 [3] 4 5
© Copyright 2000 - 2022, by Engineers Edge, LLC All rights reserved.
Disclaimer
