Engineering Design Data: Menu - excel calculators > Fluids Engineering
Fluids, Hydraulics Excel Applications
Next Page
Pages: [1] 2 3 4
Transmissivities Emissivities Constants Excel Spreadsheet Calculator
Transmissivities, Emissivities, Spectral Absorption Coefficients, Total Emission and Planck mean absorption coefficients Excel Spreadsheet Calculator
Pressurized Gas Blowout Time Excel Spreadsheet Calculator
Pressurized Gas Blowout Time Pipeline Excel Spreadsheet Calculator Mass Flow Rate for Gas Pipeline Blowdown through Hole or Orifice Excel Spreadsheet Calculator
API Separator Sizing Macro-Enabled Excel Spreadsheet Calculator
API Separator Sizing Macro-Enabled Excel Spreadsheet Calculator - easy and simple approach to (2/3 phase and vertical/horizontal) separator sizing. Formulae and references are also provided for process engineers to edit/duplicate this work
Pressure Relief Devices Sizing Macro Excel Spreadsheet Calculator
Macro-enabled MS Excel workbook for the sizing of single phase (gas or liquid) pressure relief devices. You must allow macros to be enabled to use this workbook.
Thermal Relief Load and Pressure Excel Spreadsheet Calculator
Thermal Relief Load and Pressure Rise Macro Excel Spreadsheet Calculator
High Density Polyethylene (HDPE) Liners For Steel Pipe Excel Spreadsheet Calculator
HDPE lining can be used to rehabilitate existing pipelines since HDPE is excellent for bridging holes and spanning gaps often caused by corrosion and erosion. HDPE lining can also improve the flow characteristics of the pipeline, because, although there is a slight reduction in inside diameter of the host pipe, the absolute roughness of HDPE is approximately 30 times lower (smoother) than new carbon steel.
Storage Tank Baffle Design Excel Spreadsheet Calculator
Baffles are required in almost all mixing applications. This excel spreadsheet template contains a series of calculation sheets to assist you in calculating the baffles dimension and position in a tank, when the tank has a central agitator.
Water Hammer Accumulator Sizing Excel Spreadsheet Calculator
Simple method for sizing of an air vessel for surge or water hammer attenuation in long-distance pumped liquid pipelines.
Actual Contaminated Firewater Volume Excel Spreadsheet Calculator
In the analysis of fire accidents in process plants, the main attention is usually given to the damages caused by fire to personnel, equipment and structures, while the environmental issues due to contamination by means of polluted firewater are often underestimated, even though they can also lead to severe consequences.
Slug Length and Slug Volume Pipeline Flow Excel Spreadsheet Calculator
Mean Slug Length and Slug Volume in Multiphase Horizontal Pipeline Flow Excel Spreadsheet Calculator
Next Page
Pages: [1] 2 3 4
© Copyright 2000 - 2023, by Engineers Edge, LLC All rights reserved.
Disclaimer
