Compressed Air Design Equations
Fluids Design Engineering Resources
The horse power required for adiabatic compression of air can be expressed as:
HP = [ (144 N P V n / 33000 (n - 1)) ] x [(P2 / P)((n - 1)/Nn) - 1]
Where
HP = horsepower
N = number of compression stages
n =  1.00  to 1.41 exponent of the compression curve adiabatic expansion coefficient
P = Atmospheric pressure (psi) (14.7 psi at sea level)
P2 = absolute terminal pressure after compression (psi)
V = volume of air at atmospheric pressure (cfm)
Horsepower required to compress isothermally for free air to a known pressure:
HP = (144 P V / 33,000) x (loge(P2/P))
Natural logarithims can be determined by maultiplying common logarithims by 2.30259.
Work required to compress air:
Total work ft-lbs = 3.46 P1 V1 [(P2/P1)0.29 - 1)]
and
The total work required for isothermal compression is:
Total work, Ft-Lbs =  P1 V1 Loge (V1/V2)
V1 = Initial volume absolute pressure psi
V2 = Volume of compressed air
P1 – Initial absolute pressure psf
P2 = Absolute pressure psf
Cubic feet of either compressed air or free air:
cu.ft. comp. air X (psig + 14.7) = cu.ft. free air X 14.7
  • cu.ft. comp. air [ Cubic Feet of Compressed Air ]
  • cu.ft. free air [ Cubic Feet of Free Air ]
Related Resources:
Contribute Article
© Copyright 2000 - 2018, by Engineers Edge, LLC www.engineersedge.com
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
