Engineering Design Data: Menu - fluid flow
Fluids Flow
Prev Page | Next Page
Pages: 1 [2] 3 4 5 6 7 >>
Copper Pipe Flow Friction Loss Size 0.5 to 1.00 inch diameter
Friction Losses to Water Flow in Copper Pipes Size 0.5 to 1.00 inch diameter. Tables are for Copper pipe with a surface roughness of C=130.
Copper Tubing Friction Flow Losses Pipes 1.25 to 1.50 inch dia.
Copper Tubing Friction Flow Losses of Water in Copper Pipes Size 1.25 to 1.50 inch diameter. Tables are for Copper pipe with a surface roughness of C=130.
Friction Flow Losses Copper Tubing 2 to 3 inches dia.
Friction Flow Losses in Copper Tubing of Water in Sizes 2 to 3 inch diameter
Steel Pipe Flow Friction Loss for sizes 10" to 12 " inch diameter
Steel Pipe Flow Friction Loss for sizes 10" to 12 " inch diameter. Tables are for steel pipe with a surface roughness of C=100.
Steel Pipe Flow Loss Friction for sizes 4 " to 8 " inch diameter
Steel Pipe Flow Loss Friction for sizes 4 " to 8 " inch diameter. Tables are for steel pipe with a surface roughness of C=100.
Friction Loss in Steel Pipe 1.5" to 3" inch diameter
Friction Loss in Steel Pipe size 1.5" to 3" inch diameter. Tables are for steel pipe with a surface roughness of C=100.
Friction Losses in Steel Pipes size 0.5 to 1.25 inch diameter
Friction Losses in Steel Pipes size 0.5 to 1.25 inch diameter. Tables are for steel pipe with a surface roughness of C=100. To adjust for different surface roughness factors, use the following correction factors:
Impulse-Momentum Principle For Fluids Formula
The Impulse-Momentum Principle is derived from Newton's 2nd law in vector form which states that the rate of change of linear momentum of a body is directly proportional to the external force applied on the body, and this change takes place always in the direction of the force applied.
Fuel Oil Pipe Sizes Table
Pipe Sizes for Fuel Oil Table Oil Suction - The following are the recommended Nominal Size for Fuel Oil Suction line from the storage tank to the supply pump.
Properties of Water at Atmospheric Pressure Given in Metric SI Units
Properties of Water at Atmospheric Pressure Given in Metric SI and imperial Units
Disclaimer
