Engineering Design Data: Menu - fluid flow
Fluids Flow
Prev Page | Next Page
Pages: << 4 5 6 [7] 8 9 10 >>
Engineering Applications Of Fluid Mechanics
The controlling importance of flow phenomena in nearly every type of machine and process led to the conversion of a traditional course in hydraulics into a more fundamental treatment of the action of fluids generally. The authors were more anxious that the student understand flow phenomena that he be familiar with details of many practical devices.
Flow Losses for Valves and Fittings
Flow Losses for Valves and Fittings in Equivalent Feet if Pipe. Losses are assumed with device in full open position.
Compressibility factor for air Z
Hollow Hemisphere Flow on Convex Face Surface Drag, Drag Coefficient Equation and Calculator
Solid Hemisphere Flow on Convex Face Surface Drag, Drag Coefficient Equation and Calcul
Solid Hemisphere Flow on Convex Face Surface Drag, Drag Coefficient Equation and Calculator
Ellipsoid Surface Drag , Drag Coefficient Equation and Calculator
Ellipsoid Surface Drag, Drag Coefficient Equation and Calculator
Long Symmetrical Airfoil Drag, Drag Coefficient Equation and Calculator
Long Symmetrical Airfoil Surface Drag, Drag Coefficient Equation and Calculator
Long Elliptical Section Surface Drag, Drag Coefficient Equation and Calculator
Sphere Surface Drag Drag Coefficient Equation and Calculator
Sphere Surface Drag, Drag Coefficient Equation and Calculator
Cube Flow Perpendicular Edge Surface Drag, Drag Coefficient Equation and Calculator
Cube Flow Perpendicular to Edge Surface Drag, Drag Coefficient Equation and Calculator
Disclaimer
