Related Resources: fluid flow
Stagnation Pressure Incompressible Fluid
Fluid Flow Engineering and Design
Thermodynamics
Pitot Tube Velocity of Fluid Flow Measurement
Pitot tube stagnation pressure equation for an incompressible fluid
Pitot Stagnation pressure Measurement
v = [ ( 2 / ρ ) ( Po - Ps ) / γ ]0.5
v = [ 2 g ( Po - Ps ) / γ ]0.5
where
v = velocity of the fluid (ft / sec)
Po = stagnation pressure (lbm / ft2)
Ps = static pressure of the fluid at the elevation
where the measurement is taken (lbm / ft2)
g = gravity acceleration of gravity (32.2 ft / sec2)
ρ = density of air (lbm / ft3)
γ = specific weight of fluid (lbm / ft3)
Standard air density = 1.225 kg / m3 = .07492 lbs/ft3
Eq. 3
γ = ρ g
For a compressible fluid. Use the equation for an incompressible fluid if the Mach number ≤ 0.3.
- Pitot Tube Type Flow Detector Basics Review | Engineers Edge
- Properties of Air Ideal Gas
- Gas Flow Rate Through Orifice Equations and Calculator per. ISO 5167
- Venturi Flow Equation and Calculator
- Nozzle Venturi and Orifice Flowmeter Formula and Calculator
- Aviation Maintenance Technician Handbook Airframe (FAA-H-8083-31A) Volume 2
- Compressible Flow of an Ideal Gas
- Application of Bernoulli's Equation to a Venturi - Fluid Flow Hydraulic and Pneumatic
- Vane Type Air Compressor Review and Design Equations
Source
2013 ASHRAE Handbook - Fundamentals, ASHRAE: 2013.
