Thin Perforated Plate Head Loss Coefficient Equation and Calculator
Fluids Flow Engineering
Head loss and head loss coefficient equation and calculator of a fluid in across a thin perforated plate (plate thickness / hole hydraulic diameter < 0.015) inside a pipe. Reynolds number is assumed greater than 105 .
The head loss hLcan be calculated as:
hL= kloss x (um2 / (2 x g) )
Where k loss is the head loss coefficient, (um is the mean flow velocity in the pipe, and g is the gravitational acceleration. kloss is calculated from:
k loss equation
um = Flow Velocity m/s
hL = Head Loss (m)
kloss = Head Loss - dimension less
FAR = Free or Open Area / Total Area
g = 9.80665 m/s2 or 32.174 ft/s2
References
Idel'chik, I E. and Fried, Erwin., Flow Resistance, a Design Guide for Engineers , Taylor & Francis, Washington D.C. 1989. p 260.
Contribute Article
© Copyright 2000 - 2018, by Engineers Edge, LLC www.engineersedge.com
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
