Engineering Design Data: Menu - heat transfer
heat_transfer
  • HeatConductionPipeInsulation
  • heatlossinsulatedpipe
  • Prev Page | Next Page
    Pages: 1 [2] 3 4 5 6 7 >>
    Thermal Conductivity Propylene Glycol
    Thermal Conductivity of Aqueous Solutions of Propylene Glycol. Concentrations in Volume Percent Propylene Glycol
    Viscosity of Propylene Glycol
    Viscosity of Aqueous Solutions of Propylene Glycol. Concentrations in Volume Percent Propylene Glycol
    Specific Heat of Propylene Glycol
    Specific Heat of Aqueous Solutions of Propylene Glycol. Concentrations in Volume Percent Propylene Glycol
    Inhibited Aqueous Solutions Ethylene Glycol Antifreeze Density
    Inhibited Aqueous Solutions Ethylene Glycol Antifreeze Density - Concentrations in Volume Percent Propylene Glycol Antifreeze
    Viscosity of Aqueous Solutions of Ethylene Glycol Antifreeze
    Ethylene Glycol Antifreeze - Concentrations in Volume Percent Ethylene Glycol (AntiFreeze)
    Thermal Conductivity Antifreeze Ethylene Glycol
    Aqueous Solutions of Antifreeze Ethylene Glycol Concentrations in Volume Percent
    Fuel Gas and Heating Values
    Natural gas, LPG, and propane are commonly used fuel gases. LPG is a mixture of propane and butane. It is generally transported and stored in liquid form.
    Minimum Duct Insulation R-Value
    Thermal insulation is commonly used to reduce energy consumption of HVAC systems and equipment. Minimum insulation levels for ductwork and piping are often dictated by energy codes, many of which are based on ASHRAE Standards
    Grashof Number (GR)
    The Grashof number is used to determine the heat transfer coefficient under free convection conditions. It is basically a ratio between the buoyancy forces and viscous forces.
    Water Vapor Released by Humans
    Water Vapor Released by Human Activity and Plants Estimating moisture loads requires knowledge of occupancy patterns and releases per individual, activity, plant, and water surface present
    Disclaimer
