Engineering Design Data: Menu - heat transfer
heat_transfer
  • HeatConductionPipeInsulation
  • heatlossinsulatedpipe
  • Prev Page | Next Page
    Pages: << 5 6 7 [8] 9 10 11 >>
    Boiling and Freezing Point Properties of Selected Substances
    Boiling and freezing point properties of selected substances
    Nusselt Number for Forced Convection
    Empirical correlations for the average Nusselt number for forced convection over a flat plate and circular and noncircular cylinders in cross flow
    Water Saturation Pressure Temperature
    The partial pressure of water vapor in saturated air is called the saturation pressure Psat.
    Unit Thermal Resistances Well Sealed Air Spaces
    Unit thermal resistances (R-values) of well-sealed air spaces (from ASHRAE Handbook of Fundamentals, Ref. 1, Chap. 22, Table 2)
    Thermal Contact Conductance Metal Surfaces Air
    Thermal contact conductance of some metal surfaces in air (from various sources)
    Unit Thermal Resistance Building Materials
    Unit thermal resistance (the R-value) of common components used in buildings
    Conductive Heat Transfer Sphere Buried Insulated Equation and Calculator
    Conductive Heat Transfer of a Isothermal sphere buried in a semi-infinite medium at T2 whose surface is insulated
    Conductive Heat Transfer Isothermal Sphere Equation and Calculator
    Conductive Heat Transfer of a Isothermal sphere buried in a semi-infinite medium equation and calculator
    Conductive Heat Transfer Corner Three Walls Equation and Calculator
    Conductive Heat Transfer of a Corner of three walls of equal thickness equation and calculator
    Conductive Heat Transfer Two Adjoining Walls Equation and Calculator
    Conductive Heat Transfer of the edge of two adjoining walls of equal thickness
    Disclaimer
