Engineering Design Data: Menu - heat transfer
heat_transfer
  • HeatConductionPipeInsulation
  • heatlossinsulatedpipe
  • Prev Page | Next Page
    Pages: << 6 7 8 [9] 10 11 12
    Conductive Heat Transfer of a Disk Equation and Calculator
    Conductive Heat Transfer of a Disk buried parallel to the surface in a semi-infinite medium (z >> D)
    Conductive Heat Transfer Spherical Layer Equation and Calculator
    Conductive Heat Transfer of a spherical layer equation and calculator
    Conductive Heat Transfer Square Pipe Equation and Calculator
    Conductive Heat Transfer of a Square Pipe of known wall thickness equation and calculator
    Conductive Heat Transfer Pipe Equation and Calculator
    Conductive Heat Transfer of a Cylindrical Pipe or Layer Equation and Calculator
    Conductive Heat Transfer Large Plane Wall Equation Calculator
    Conductive Heat Transfer of Large plane wall equation and calculator.
    Conductive Heat Transfer Eccentric Cylinder Equation and Calculator
    Conductive Heat Transfer of Eccentric circular isothermal cylinder of length L in a cylinder of the same length (L > D2).
    Conductive Heat Transfer Square Solid Equation and Calculator
    Conductive Heat Transfer of Circular isothermal cylinder of length L at the center of a square solid bar of the same length
    Conductive Heat Transfer Cylinder of Length Equation and Calculator
    Conductive Heat Transfer of Circular isothermal cylinder of length L in the midplane of an infinite wall (z > 0.5D)
    Conductive Heat Transfer Parallel Cylinders Equation and Calculator
    Conductive Heat Transfer of A row of equally spaced parallel isothermal cylinders buried in a semi-infinite medium (L >>D, z and w >1.5D)
    Cylinder Heat Transfer Buried in Medium Equation and Calculator
    Heat Loss of cylinder buried in a semi-infinite medium equation and calculator. Vertical isothermal cylinder of length L buried in a semi-infinite medium (L >>D)
    Disclaimer
