Engineering Design Data: Menu - hvac-systems
Hvac Systems Design and Engineering
Estimated Costs of Heating Systems
Estimated Seasonal Efficiencies and Annual Costs of Heating Systems
Minimum Ventilation Rates in Rooms
Minimum Ventilation Rates in the Breathing Zone, Based on ANSI/ASHRAE Standard 62.1-2007
Temperature and Pressure Data for Refrigerants
Refrigerant data for R717, R134a, R22, R507, R290, R744, Temp, ◦F
Duct Design Air Flow Velocities
HVAC - air conditioning and heating systems usually require some form of duct system to channel air to places where the conditioned air is needed. A poor HVAC dust design, faulty installation installation job will result in poor performance, bad air flow, leaky duct systems, and higher than usual energy costs.
HVAC Air Conditioning Engineering
Air conditioning (of which refrigeration is an inseparable part) has its origins in the fundamental work on thermodynamics which was done by Boyle, Carnot and others in the seventeenth and eighteenth centuries, but air conditioning as a science applied to practical engineering owes much to the ideas and work of Carrier, in the United States of America, at the beginning of this century.
Psychrometric Chart 7500 ft Above Sea Level 17" x 11" in Color
Printable Psychrometric Chart US and SI Units at 7500' Above Sea Level 17" x 11" in Color
Psychrometric Chart 5000 ft Above Sea Level US and SI Units
Printable Psychrometric Chart US and SI Units at 5000' Above Sea Level 17" x 11" in Color Barometric Pressure: 29.921 Inches of Mercury (101.04 lPa), Enthalpy - BTU per Pound of Dry Air, Saturation Temperature, Enthalpy BTU per. Pound of Dry Air.
Psychrometric Chart US and SI Units at Sea Level
Printable Psychrometric Chart US and SI Units at Sea Level 17" x 11" in Color
Air Wind Flow Through Opening Calculator
Aspects of wind that affect the ventilation rate include average speed, prevailing direction, seasonal and daily variation in speed and direction, terrain, and local obstructions such as nearby buildings, hills, trees, and shrubbery.
© Copyright 2000 - 2023, by Engineers Edge, LLC All rights reserved.
Disclaimer
