Density of Various Solids Tables
Engineering Materials Specifications and Characteristics Tables and Charts - Ferrous and Non-Ferrous
These tables gives the range of density for miscellaneous solid materials whose characteristics depend on the source or method of preparation.
Material
ρ/ g cm-3
Agate
2.5-2.7
Alabaster, carbonate
2.69-2.78
Alabaster, sulfate
2.26-2.32
Albite
2.62-2.65
Amber
1.06-1.11
Amphiboles
2.9-3.2
Anorthite
2.74-2.76
Asbestos
2.0-2.8
Asbestos slate
1.8
Asphalt
1.1-1.5
Basalt
2.4-3.1
Beeswax
0.96-0.97
Beryl
2.69-2.70
Biotite
2.7-3.1
Bone
1.7-2.0
Brasses
8.44-8.75
Brick
1.4-2.2
Bronzes
8.74-8.89
Butter
0.86-0.87
Calamine
4.1-4.5
Calcspar
2.6-2.8
Camphor
0.99
Cardboard
0.69
Celluloid
1.4
Cement, set
2.7-3.0
Chalk
1.9-2.8
Charcoal, oak
0.57
Charcoal, pine
0.28-0.44
Cinnabar
8.12
Clay
1.8-2.6
Coal, anthracite
1.4-1.8
Coal, bituminous
1.2-1.5
Coke
1.0-1.7
Copal
1.04-1.14
Cork
0.22-0.26
Corundum
3.9-4.0
Diamond
3.51
Dolomite
2.84
Ebonite
1.15
Emery
4.0
Epidote
3.25-3.50
Feldspar
2.55-2.75
Flint
2.63
Fluorite
3.18
Galena
7.3-7.6
Garnet
3.15-4.3
Gelatin
1.27
Glass, common
2.4-2.8
Glass, lead
3-4
Material
ρ/ g cm-3
Pyrex
2.23
Granite
2.64-2.76
Graphite
2.30-2.72
Gum arabic
1.3-1.4
Gypsum
2.31-2.33
Hematite
4.9-5.3
Hornblende
3.0
Ice
0.917
Iron, cast
7.0-7.4
Ivory
1.83-1.92
Kaolin
2.6
Leather, dry
0.86
Lime, slaked
1.3-1.4
Limestone
2.68-2.76
Linoleum
1.18
Magnetite
4.9-5.2
Malachite
3.7-4.1
Marble
2.6-2.84
Meerschaum
0.99-1.28
Mica
2.6-3.2
Muscovite
2.76-3.00
Ochre
3.5
Opal
2.2
Paper
0.7-1.15
Paraffin
0.87-0.91
Peat blocks
0.84
Pitch
1.07
Polyamides
1.15-1.25
Polyethylene
0.92-0.97
Poly(methyl methacrylate)
1.19
Polypropylene
0.91-0.94
Polystyrene
1.06-1.12
Polytetrafluoroethylene
2.28-2.30
Poly(vinyl acetate)
1.19
Poly(vinyl chloride)
1.39-1.42
Porcelain
2.3-2.5
Porphyry
2.6-2.9
Pyrite
4.95-5.10
Quartz
2.65
Resin
1.07
Rock salt
2.18
Rubber, hard
1.19
Rubber, soft
1.1
pure gum
0.91-0.93
Neoprene
1.23-1.25
Sandstone
2.14-2.36
Serpentine
2.50-2.65
Silica, fused,
2.21
Silicon carbide
3.16
Slag
2.0-3.9
Slate
2.6-3.3
Material
ρ/ g cm-3
Soapstone
2.6-2.8
Solder
8.7-9.4
Starch
1.53
Steel, stainless
7.8
Sugar
1.59
Talc
2.7-2.8
Tallow, beef
0.94
Tar
1.02
Topaz
3.5-3.6
Tourmaline
3.0-3.2
Tungsten carbide
14.0-15.0
Wax, sealing
1.8
Wood (seasoned)
alder
0.42-0.68
apple
0.66-0.84
ash
0.65-0.85
balsa
0.11-0.14
bamboo
0.31-0.40
basswood
0.32-0.59
beech
0.70-0.90
birch
0.51-0.77
blue gum
1.00
box
0.95-1.16
butternut
0.38
cedar
0.49-0.57
cherry
0.70-0.90
dogwood
0.76
ebony
1.11-1.33
elm
0.54-0.60
hickory
0.60-0.93
holly
0.76
juniper
0.56
larch
0.50-0.56
locust
0.67-0.71
logwood
0.91
mahogany
0.66-0.85
maple
0.62-0.75
oak
0.60-0.90
pear
0.61-0.73
pine, pitch
0.83-0.85
white
0.35-0.50
yellow
0.37-0.60
plum
0.66-0.78
poplar
0.35-0.50
satinwood
0.95
spruce
0.48-0.70
sycamore
0.40-0.60
teak, Indian
0.66-0.98
walnut
0.64-0.70
water gum
1.00
willow
0.40-0.60
Wood’s metal
9.70
References
1. Forsythe, W. E., Smithsonian Physical Tables, Ninth Edition, Smithsonian Institution, Washington, 1956.
2. Kaye, G. W. C., and Laby, T. H., Tables of Physical and Chemical Constants, 16th Edition, Longman, London, 1995.
3. Brandrup, J., and Immergut, E. H., Polymer Handbook, Third Edition, John Wiley & Sons, New York, 1989.
