Various Types of Adhesives Typical Mechanical Performance
Strength and Mechanics of Materials
Materials Chemicals and Adhesives
Typical Mechanical Performance of Various Types of Adhesives and their
By strict definition, an adhesive is any substance that fastens or bonds materials to be joined (adherends) by means of surface attachment. The bond durability depends on the strength of the adhesive to the substrate (adhesion) and the strength within the adhesive (cohesion). Besides bonding a joint, an adhesive may serve as a seal against foreign matter. When an adhesive performs both bonding and sealing functions, it is usually referred to as an adhesive sealant. Joining materials with adhesives offers significant benefits compared with mechanical methods of uniting two materials.
Adhesive Chemistry or Type
Room Temperature
Lap-Shear Strength
Pel Strength
Per Unit Width
MPa
psi
kN/m
lb/in
Pressure-sensitive
0.01 - 0.07
2 - 10
0.18 - 0.88
1 - 5
Starch-based
0.07 - 0.7
10 - 100
0.18 - 0.88
1 - 5
Cellosics
0.35 - 3.5
50 - 500
0.18 - 1.8
1 - 10
Rubber-based
0.35 - 3.5
50 - 500
1.8 - 7
10 - 40
Formulated hot melt
0.35 - 4.8
50 - 700
0.88 - 3.5
5 - 20
Synthetically designed hot melt
0.7 - 6.9
100 - 1,000
0.88 - 3.5
5 - 20
PVAc emulsion (white glue)
1.4 - 6.9
200 - 1,000
0.88 - 1.8
5 - 10
Cyanoacrylate
6.9 - 13.8
1,000 - 2,000
0.18 - 3.5
1 - 20
Protein-based
6.9 - 13.8
1,000 - 2,000
0.18 - 1.8
1 - 10
Anaerobic acrylic
6.9 - 13.8
1,000 - 2,000
0.18 - 1.8
1 - 10
Urethane
6.9 - 17.2
1,000 - 2,500
1.8 - 8.8
10 - 50
Rubber-modified acrylic
13.8 - 24.1
2,000 - 3,500
1.8 - 8.8
10 - 50
Modified phenolic
13.8 - 27.6
2,000 - 4,000
3.6 - 7
20 - 40
Unmodified epoxy
10.3 - 27.6
1,500 - 4,000
0.35 - 1.8
2 - 10
Bis-maleimide
13.8 - 27.6
2,000 - 4,000
1.8 - 3.5
1 - 20
Polyimide
13.8 - 27.6
2,000 - 4,000
0.18 - 0.88
1 - 5
Rubber-modified epoxt
20.7 - 41.4
3,000 - 6,000
4.4 - 14
25 - 80
  • Budynas, Richard G., and J. Keith Nisbett, Shigley's Mechanical Engineering Design, 8th ed., New York: McGraw-Hill, 2008.
