Engineering Design Data: Menu - mechanical-tolerances
Mechanical Tolerances
Next Page
Pages: [1] 2 3 4
Formulas International Tolerance (IT) Grades
Formulas for Standard International Tolerance (IT) Grades per.ISO 286-1 1993 and ISO 919-1993
Machined Tool Relief Grooves Dimensions and Tolerances
Size, Dimensions and Tolerances for Machined Tool Relief Grooves
Shaft to Shaft Axial Alignment Tolerances
Design for shaft-to-shaft alignment is the positioning of the rotational centers of two or more shafts so that the shafts are co-axial when the machine is in operation.
Housing Tolerance Classifications for Metric Radial Ball and Roller Bearings
Selection of Housing Hole Tolerance Classifications for Metric Radial Ball and Roller Bearings of ABEC-1 and RBEC-1 Tolerance Classes
Shaft Tolerance Radial Ball and Roller Bearings
Shaft Tolerance Classifications for Metric Radial Ball and Roller Bearings of ABEC-1 and RBEC-1 Tolerance Classes ANSI/ABMA 7
Engineering Tolerances
A Study of tolerance limits and fits for engineering purposes, with full tables of all recognized and published tolerance systems.
Measuring Pitch Diameters using Three Wire Method
The pitch diameter of a screw thread may be measured very accurately by means of some form of dial caliper or micrometer and three wires of equal diameter.
Measuring and Designing Dovetail Slides
Dovetail slides that must be machined accurately to a given width are commonly gaged by using a gage pin of known diameter and measured as indicated by the dimensions x and y
Drill and Counterbore Sizes for Socket Head Cap Screws per. ASME B18.3
Composite Position Tolerance Calculator GD&T for External FOS
GD&T Composite Position Tolerance Calculator for Dimensional Inspection: External Feature of Size - post, tab, pipe, etc...
Next Page
Pages: [1] 2 3 4
© Copyright 2000 - 2021, by Engineers Edge, LLC All rights reserved.
Disclaimer
