Geneva Internal Mechanism Design Equation and Calculator
Machine Design and Mechanics
Geneva Internal Mechanism Design Equation and Calculatorr
The Geneva Mechanism or Maltese cross is a gear mechanism that translates a continuous rotation movement into intermittent rotary motion.
The rotating drive wheel is usually equipped with a pin that reaches into a slot located in the other wheel ( driven wheel ) that advances it by one step at a time. The main wheel also has an elevated circular blocking disc that "locks" the rotating driven wheel in position between steps.
Geneva Mechanism Animation
Geneva Mechanism Internal Design Equations
Internal Geneva mechanism (six-slot internal Geneva wheel)
Internal Geneva mechanism (six-slot internal Geneva wheel).
Internal Geneva Mechanicsm Geometry
Kinematics of the Internal Geneva Drive. Assumed or given: a, n, d, and p.
a = crank radius of driving member
and
m = 1 / ( sin (180/n) )
n = number of slots in drive
d = roller diameter
p = constant velocity of driving crank, rpm
b = center distance = am
D = Inside diameter of driven Geneva wheel
ω = constant angular velocity of driving crank = pπ/30 rad/sec
α = angular position of driving crank at any time
β = angular displacement of driven member corresponding to crank angle α.
Angular Velocity
Angular Acceleration
Maximum angular acceleration occurs when roller enters slot and equals
Handbook of Machining and Metal Working Calculations, Ron A. Walsh 2001
