Flywheel Mass Size Design Equation and Calculator |
The large variation that is possible between different machine designs shows that dynamic measurement or kinematic analysis is necessary to determine the torque fluctuation. It is often necessary, however, to come up with a rough estimate for preliminary design purposes or for checking the reasonableness of calculated values. |
V-Belt Angle Between Two Sheave |
V-belts are used to transmit power from motors to machinery. Sheaves have a V-groove. Pulleys have a flat circumference. A V-belt may be used in combination with a drive sheave on a motor shaft and a pulley on the driven shaft.
Equation and Calculator to determine the v-belt angle between the two sheave pulley's. |
Multi Plate Disk Clutch Design |
Multi Plate Disk Clutch Design A number of double-sided friction plates may be mounted on splines on one element, and corresponding steel contacting plates on splines on the other element. |
