Wind Turbine Power From Wind |
Energy available in wind is basically the kinetic energy of large masses of air moving over the earth’s surface. Blades of the wind turbine receive this kinetic energy, which is then transformed to mechanical or electrical forms, depending on our end use. |
Universal Joint Maximum Minimum Speed |
This form of coupling, originally known as a Cardan or Hooke's coupling, is used for connecting two shafts the axes of which are not in line with each other, but which merely intersect at a point. |
Motor Car Engineering Text Book Volume I Construction |
Published in 1911 this book is primarily intended for the use of students of Motor Car Engineering ; but it is hoped that many engaged in this branch of Engineering science, including owners of cars, will derive some benefit from a perusal of this volume, which has been mainly written from the notes used by the Author in his lectures to Ordinary and Honors Grade Students at the Polytechnic School of Engineering |
Truck and Car Axle Load Equations |
To optimize the vehicle and achieve the correct superstructure ratings, an axle load calculation is essential. The body can be matched properly to the truck only if the vehicle is weighed before any body building work is carried out. |
Pelton Wheel Review |
Modern impulse turbines are generally know as Pelton type and are restricted to relatively high-head applications . One or more jets of water impinge on a wheel containing many curved buckets. |
