Finite Element Analysis Framework Python Application Script
This applications is a python-based finite element analysis framework for education and research purpose by Dr. Pei Yaoyao at the sponsor of Hubei Univeristy of Technology!
Download: Numerical Analysis of Fluids Application
Elements supported
- Spring1D11
- Spring2D11
- Spring3D11
- Link1D11
- Link2D11
- Link3D11
- Beam1D11
- Beam2D11
- Beam3D11
- Tri2d11S---- Triange elements for plane stress problem
- Tri2D11 ---- Triange elements for plane strain problem
- Tetra3D11
- Quad2D11S
- Quad2D11
- Plate3D11 ---Midline plate
- Brick3D11
We name the elements with "Name" + "dimension" + 'order" + "type", type 1 means elastic .
Truss
Frame with Hinged Node
Embedded Wall Design
Fluid flow problem
Python Module Requirements
numpy
scipy
matplotlib
numpydoc
sphinx==6.2.1
sphinx-autoapi
sphinx-copybutton
sphinx-gallery
sphinx-book-theme
esbonio
Mpmath
Source
References
- Tiitinen, Hinkkanen, Harnefors, “Stable and passive observer-based V/Hz control for induction motors,” Proc. IEEE ECCE, Detroit, MI, Oct. 2022
- Tiitinen, Hinkkanen, Kukkola, Routimo, Pellegrino, Harnefors, “Stable and passive observer-based V/Hz control for synchronous Motors,” Proc. IEEE ECCE, Detroit, MI, Oct. 2022
- Pellegrino, Armando, Guglielmi, “Direct flux field-oriented control of IPM drives with variable DC link in the field-weakening region,” IEEE Trans.Ind. Appl., 2009
- Awan, Hinkkanen, Bojoi, Pellegrino, “Stator-flux-oriented control of synchronous motors: A systematic design procedure,” IEEE Trans. Ind. Appl., 2019
- Kim, Ha, Sul, “PWM switching frequency signal injection sensorless method in IPMSM,” IEEE Trans. Ind. Appl., 2012
Support:
- Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
- Supporting Windows application "Visual Studio Code".
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- Finite Element Analysis FEA Review
- Incorporating Engineering Ethics for the Credibility of FEA Results
- 2D Finite Element Analysis Spreadsheet Calculator
- Analysis of Stress and Deformation , George W. Housner, Thad Vreeland, Jr., Division of Engineering and Applied Science, California Institute
- Computational Dynamics Free Membership Required
- Structural Composite Sandwich Stiffness Equation and Calculator
- Structural Composite Sandwich Wrinkling Stress Equation and Calculator
- Structural Composite Honeycomb Core Wrinkling Stress Equation and Calculator
- Stress Analysis Manual Premium Membership Required
- Instrumentation & Control Devices Capacitance Discharge Calculator, How a Flip Flop Circuit Works, Inductance of Coil Calculator, Ohms Law Equations and Calculator, Resistors in Parallel Equation and Calculator, Wheatstone Bridge Analysis and Calculator, Power Transistor on Heat Sink Calculator, Zener Diode and Resistor Voltage Regulator Design Calculator
- Inelastic Analysis of Geometrically Exact Rods In this work a formulation for rod structures able to consider coupled geometric and constitutive sources of nonlinearity in both the static and the dynamic range is developed. Additionally, it is extended for allowing the inclusion of passive energy dissipating elements as a special rod element and geometric irregularities as a full three-dimensional body connected to the framed structure by means of a two-scale model.
- Mechanical Design Handbook , Peter R. N. Childs, 373 pages
- Mechatronics Design, Engineering and Manufacturing
Technologies, Principles, Design, and Analysis of Comple Electro-Mechanical Systems - Thick Wall Cylinder Press or Shrink Fits Interference and Pressure Equations and Calculator If two thick-walled cylinders are assembled by either a hot/cold shrinking or a mechanical press-fit, a pressure is developed at the interface between the two cylinders.
- Press Fit Engineering and Design Calculator
- Diameter Change for Cylinder Press and Shrink Fits Analysis Equations and Calculator
- Interference Fit Force Required the Press Together Hub and Shaft Equations and Calculator
- Statics and Dynamics, Introduction
** Free Membership Minimum Required ** - Steel Pipe Clamps Stress and Friction Capacity Analysis
- Spring Design Application Belleville Spring Washer, Coil Spring, Compression Spring Calculator, Extension Spring Calculator, Torsion Spring Calculator, Spring Properties and Material
- Structural Theory Handbook Premium Membership Required to view Document/Book
- Static Temperature Versus Total Temperature Formula and Calculator When a fluid stream impinges on a temperature-sensing element such as a thermometer or thermocouple, the element is at a temperature greater than the true stream temperature.
- Structural Composite Sandwich Design and Analysis in Aerospace Applications
