We are building a Vertical Axis wind turbine with straight vertical blades and struts. The struts are attached to the central column or pipe at several positions along the pipe. The rotor is inside a frame so the pipe is supported at the top and bottom. The turbine provides a thrust load which in turn creates a deflection at the pipe. Does anyone know how to design the pipe so the operating speed is below the critical speed?
