Results 1 to 8 of 8
Thread: How to convert pdf to dwg files?
    Apr 2011
    I have some pdf files that need to convert to editable dwg files. Anyone could give me some advices.
    Thanks.
    1,045
    Hi Donald,
    Later versions of CorelDraw will convert PDF to DXF which is AutoDesk's file-exchange version of DWG drawings.
    Dave
    Generally, I will not give you the answer to your question, but I **will** guide you into discovering how to solve this yourself.
    Apr 2011
    Monclova, Coahuila, Mexico
    39
    I have worked with PDF to DWG converter and this program works well. find it in google.
    regards,
    Nov 2011
    Quote Originally Posted by Dominguez Mexico View Post
    regards,
    is that software for free download?
    Mar 2012
    My advise would probably be very amateur but then the easiest way i could think of.
    Google yourself a converter, its that easy! i google my file converters all the time and they work perfectly. Its actually convenient cause you wont have to install a software and all, you can convert it straight up so its really simple.
    I suggest though that if you are to convert numerous files then you really have to download and install a software
    Apr 2012
    Soochow,China
    convert pdf to dxf? it's surprising to me.
    1,045
    Why? They are both Vector based.
    May 2012
    Donald I can help you with that.
