Threads 1 to 20 of 344
    04-11-2024, 06:39 AM Go to last post
  1. Unequally Disposed Profile
    03-02-2024, 08:44 AM Go to last post
  2. Feature of size
    02-27-2024, 04:17 AM Go to last post
  3. Auto wheel bearing run out stack up
  4. Basic dim's interpretation
  5. Hole pattern on narrow edge datum precedence
  6. two perpendicular axes as DRF?
    datum, drf, gd&t
  7. Slot True Position
  8. Position tolerance with parallelism
  9. Profile of a line on a drawing?
  10. surprise2 Heat Treat callout
  11. :bash: Flatness and surface finish spec
    Started by chrishilton979, 03-20-2023 10:15 AM
    03-21-2023, 07:20 AM Go to last post
    01-27-2023, 09:11 AM Go to last post
  12. Lightbulb Boundaries & there Purpose
    Started by Jkirk, 01-03-2023 07:36 AM
    01-03-2023, 08:25 AM Go to last post
  13. BSC dimension tolerance
    Started by kreits, 11-09-2022 01:52 PM
    11-10-2022, 11:01 AM Go to last post
Forum Information and Options
Moderators of this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
