Results 1 to 8 of 8
Thread: I beam size.
    Banned
    May 2013
    I beam size.
    I have a 4 story house and Id like to make a swing stagesystem for it to gain access to a few of the otherwise unreachable walls. Id like to use a collapsible swing 6 wideetc. To traverse the walls horizontally, Ill need a trolley system and thus anI beam track above.
    Its the I beam sizing that is in question. Id like the beam to be capable of 1000lbscapacity load at the combined trolleys which will be separated by a 6 spreaderbar. The span of the Beam will be just under 9 between supports. My questionis; will a common 2.5 X 4 steel I beam suffice? If not, what would the minimum size?
    Thanks,
    Mike Smallwood
    Banned
    May 2013
    A picture you say eh?
    Sorry I don’t know how to draw pictures. Maybe below will help?
    If 9 white ducks are in a line on a pond and two additional ducks that are yellow always stay next to the white ducks and the two yellow ducks additionally always stay 6 white ducks away from one another; how many white ducks can a yellow duck swim along side of?
    Answer-3
    Now mentally visualize the 9 white ducks and imagine they mysteriously become an I beam 9' long. Now visualize the 2 yellow ducks and imagine they become two yellow trolleys with a 6 foot spreader bar always distancing them from one another. How far can the trolley move along the beam in either direction? Now imagine the trolleys carry a 1000lb load (500lbs ea) of magic green sparkling sugar that mysteriously becomes a person and tools on a swing stage.
    Need a picture of one beam trolley on a beam too? That I can do.
    2,615
    If a chicken and a half can lay an egg and a half in a day in a half, how long would it take a grass hopper with a wooden leg to separate all the seeds out of a dill pickle?
    What does a grass hopper separating seeds from a pickle got to do with chickens?
    The best answer comes from the best question......
    The solution to your original post is within the link below.
    https://www.engineersedge.com/beam_b...calculator.htm
    This tool will determine requirements per. AISC 9th Edition ASD Manual and CMAA Specification No. 74 (2004).
    Quote Originally Posted by Tradewinds63 View Post
    Sorry I dont know how to draw pictures. Maybe below will help?
    Answer-3
    Ducks, eggs and grasshoppers aside, you will catch more flies with honey than vinegar.
    This could have all been done for you if only you had supplied a sketch of what you required. So now you are left with the online calculator and your wit.
    That seemed to work well for you.
    I can't understand why you need to bother with trolleys when you're only moving what would be an arms reach away either direction? 1-1/2 ducks left of center... 1-1/2 ducks to the right...?
    When you say collapsible swing... you lost me there...?
    Maybe you should look into a rolling library ladder? There are some really good looking systems out there... Maybe a window washers rigging?
    Jun 2013
    7
    I do agree with Kelly. It will be more understandable if there are more pics. What do you think?
    Jun 2013
    5
    RWOLFEJR is right. You should try other systems.
