Thread: HELP!!!! - Basic Statics Question
    Oct 2013
    Ok Everyone, I'm in DIRE NEED OF HELP....
    .... as I've been out of practice now for a while - though I'm sure this is an easy problem to solve. Please see attached free body diagram.
    Need to find reactions, R1, R2, R3 to support a 185 lb load as per the attached. I have done summation of forces R1 + R2 + R3 - 185 = 0 and summation of Moments about R1=0. What's my 3rd equation?!?!?!?
    Attached Files Attached Files
    2,622
    Sum of Forces = 0 = R1 - 185# + R2 + R3
    185# = R1 + R2 + R3
    R1 = R2 + R3 - 185#
    etc...
    Sum of Moments about 185# = 0 = -13(R1) + 10(R2) + 25(R3)
    Substitute and solve for R1, R2 and R3
    http://www.engineersedge.com/video/S...Problems_v1145
    But from what I see it looks like R2 and R3 are sharing the load. The actual load at each point is going to depend on the stiffness of the beam and could range from zero to the full load based on its position.
    it's statically indeterminate, you have more unknowns than equations... it can be solved but it's not as straightforward as you'd expect. There are several methods for solving statically indeterminate problems, the most popular one is probably the moment distribution method.
    Just as an FYI, most structures in the real world are statically indeterminate. They can be solved by hand but depending on the degree of indeterminacy it can take a very long time. In these cases computers are very useful.
