Thread: Filters Backwash - Water treatment
    Oct 2013
    I have two alternatives from which I need to choose:
    First:
    used backwash water shall be recirculated to the head of the water treatment
    without any further treatment.
    Second:
    Designing a separate treatment for the used backwash water.
    The water treatment includes coagulation & flocculation, sedimentation and filtration.
    Can you please advise me why should I design a special side process for the used
    backwash water? In any case, most of the side treatments include the same
    processes as the main line.
    Source of water is a river and capacity is pretty low (about 700 m3/hr)
    Thanks,
    David
    2,544
    Welcome to EE!
    This question is way out of my knowledge realm...
    I would first suggest that you research out any local od national regulations on how to design for water treatment. If no regulation are available I would suggest using the most likely to succeed design.
    It is way easier to over engineer than to engineering it "just right"...
    Good luck
    Oct 2013
    Thanks
    Thank you
