Thread: baud rate generation in 89s52
    4
    i am doing a project in which i am interfacing 89s52 with a fingerprint scanner through uart . i want to generate 115200 baud rate through timer 1 the code is attached
    TMOD=0x20;
    TH1=0xFF;
    SCON=0X50;
    PCON=0X80;
    TR1=1;
    the crystal used is 22.1184 mhz is this code right ? and can we generate baud rate through timer 1 in 89s52?
    2,622
    Welcome to EE!
    Best I can do is attach the data sheet for the 89s52..
    AT89S52.pdf
