Results 1 to 11 of 11
Thread: Faraday Cage Issues
    Nov 2013
    6
    Question Faraday Cage Issues
    I am currently building a faraday cage to keep WiFi out - for a science experiment. However, the phone still detects WiFi when inside the cage.
    It is essentially a 40x40x40cm cardboard box wrapped in Aluminium foil, with one side being conductive mesh with more than small enough-sized gaps. There is an opening at the back which is covered in foil and secured with metal drawing pins when the cage is in use.
    The foil covers the box entirely (outside only), and in some places is double or triple-layered. It is fixed with regular transparent tape or duct tape, which covers the foil where placed. There are also staples on the corners.
    The mesh and foil overlap, and this overlap is covered in duct tape.
    We have tried earthing the cage but the effects are negligible.
    Any ideas on how we could improve the cage and solve the problem?
    Many thanks,
    Dorfkrug
    TL;DR: Our faraday cage isn't working. Why?
    P.S. I hope this is the right forum section. Please let me know if it's not.
    2,622
    Welcome to EE!
    Quote Originally Posted by Dorfkrug View Post
    You need copper or iron - aluminum doesn't work that well...
    Nov 2013
    6
    Thanks a lot Kelly!
    We will see if our school can get one of these materials for us. Which one is better or doesn't it matter?
    Senior Engineer
    Jan 2014
    58
    I’ve had good luck using copper window screen and soldering all the joints to make faraday cages. Do you have any wiring penetrating the cage? They take special precautions. If you are stuck with aluminum foil; put it together with aluminum foil tape, available at any building supply store, not duct tape. Conductivity across the joints in the cage is necessary.
    Timelord
    Nov 2013
    6
    Quote Originally Posted by Timelord View Post
    Timelord
    We did not have any wiring penetrating the cage, but will do soon, going through the mesh. Is that OK considering the wire is insulated with plastic/rubber?
    We are now trying to make a cage using only mesh, as we have found that to work better than aluminium foil. One of the reasons why it didn't work before was that, as you say, there was duct tape between the layers of foil.
    Thanks.
    Senior Engineer
    Jan 2014
    58
    You may find that a wire penetrating the cage will act like an antenna and conduct the Wi-Fi inside where it is reradiated. The solution is as simple winding your wiring thru a ring core just outside the cage which will reject any common mode signal.
    Timelord
    Nov 2013
    6
    We have not succeeded in making a Faraday cage that works 100%, but more like 70 or 80. Unfortunately we are running out of time and have to move on to the experiment the cage was originally intended for.
    But thanks a lot for your help.
    Aug 2012
    UK
    433
    What size grid did you use to make the mesh?
    Nov 2013
    6
    The squares are 65mm wide, which is much more than enough for WiFi. Using the wave equation we determined the wavelength was 12.5cm.
    Aug 2012
    UK
    433
    Academic now it's built, but perhaps the Wi Fi was running more towards the higher ranges (say between 3 to 5 GHz) which is why the cage didn't 100% work.
  11. #11
    Nov 2013
    6
    Could be. Thanks for your ideas. We will certainly add this to the report.
