Thread: Antenna Mast Design
    ant17
    Antenna Mast Design
    hi guys i wanting help with calculating the size of od of the steel pipe hat is to used as mast the mast will bee 90ft high and i want to be able to calculate the strength and size of pipe so that it does not just bend over significantly can any one guide me on how i can it have to be guyed most likeley
    2,616
    Well, what you ask is not a simple task. If you are not in the mast engineering and design business I suggest you contact an organization that specializes in this application.
    If you ambitious, see the following document:
    Guide Specifications for the Design of Metal Flagpoles FP 100-07 --> FP1001-07 (1).pdf
    Engineer
    Apr 2014
    Pittsburgh
    11
    I love the quick reply box.. makes everyone feel incapable of typing.
    I will look into my Eng Mech books.
    2,616
    Quote Originally Posted by Zach0350 View Post
    ? What does that mean...
