Thread: Pressure vessel help
    May 2014
    Hello and thank you for helping me out on this one.
    so i am trying to figure out how to make a pressure tank with materials i already have and i am worried about the endcaps. I have 20" OD stainless steel 316 with .125 wall cylinder. i also have two .125 316 flat plates that i wanted to weld on for endcaps. my working pressure would be around 100psi with a temperature around 90F. i have been looking around the interweb for the calculations for flat endcaps and cant seem to find what i need. any help would be great! Thank you for your time.
    875
    There's a reason you can't find it. Flat ends and the sharp corners they create are a very bad idea and generally do not work at all under any kind of pressure. Your end plate has 314 sq inches area. At 100 psi that's 31,400 lbs total load on your end plate. Still think it can take it?
    2,444
    The loading, as JBoggs indicated is quite large and unsupportable with a .125" thick end plate.
    You can get exact numbers with these equations and engineering calculator..
    Circular Plate deflection and Stress
    To do the conversions from imperial unit to SI.
    Inch units to mm
    psi to N/mm^2 ----> 1 psi = .00689475 N/mm^2
    inches to mm ----> 1 inch = 25.4 mm
    Also see:
    Pressure Vessel Engineering and Design
