Thread: scissors roof truss analysis and design
    Dec 2014
    Bang Head scissors roof truss analysis and design
    ipt>
    Hi, I am newbie here. I designing a scissors roof truss system currently. There are problems in my analysis. To simplified the question, I omitted all the dimension of the structure. My scissor roof truss is supporting by column, from the beginning, I make simply supported for the roof truss (roller and pin) to allow the lateral movement at one end of the truss. The problem arise when I found that the lateral deflection at the roller end was up to 200mm. I would like to ask about that if I assume the pin joint at both end of the roof truss, should I consider there is a lateral load apply on the top of the column? the reason is the roof truss will cause the column bend at the top, and I need to consider a lateral load on the top of the column (the lateral use to push the roof truss back to original position) as I can ensure the column will not bend over. If I doing like this, the new size of column will be much more large than the previous (simply suppoted) column right? Any of you can help me in this topic?
    2,578
    Without a free body diagram it's not clear what your'e asking. You should analyze what you intend on building...
