Thread: shaft design problem
    Feb 2015
    Dear all , i hope someone can help me solving this exercise as soon as possible .question:The shaft of the figure is manufactured from a ductile steel and has a polished surface . The shaft diameter is d=25mm. it is simply supported at points A and B and a keyway is located a point C. a perpendicular load to the shaft axis of 5 KN acts in the middle of the shaft length.
    A)Calculate the shaft safety factor for static problem.
    B)Calculate the shaft safety factor if rolling bearings are placed at points A and B and the shaft rotates. DATA:Yield stress σy=350 MPa .
    Fatigue strength σε= 241.6 MPa .
    Notched stress concentration at keyway Kf= 1.78 .
    Coefficient of size (diameter) Cs= 0.85 .
    a=10 mm.
    b=15 mm.
    c=10 mm.
    d=70 mm.
    Feb 2015
    please help me to solve it!
    Quote Originally Posted by mohamad92 View Post
    Looks like school homework... Did you read the rules when you registered for Engineers Edge forums.
